A cam question.
Old Aug 15, 2005 | 03:15 PM
Devilfish's Avatar
Default A cam question.
Hello
Im from Sweden so sorry for the bad english..
I own a corvette, but they told me that i could get better answer here then at corveteforum.com when it comes to my question.
First this is my engine.
350
scat 9000 nodular iron crank
scat 9000 fordge i-beam rods
probe fordge pistons 10:1 comp
ARP bolts everywhere
trick flow 23 heads
a converted lt1 intake from www.lt1intake.com
headers
Car is a 6spd vette 1991
Right now I use a hotcam with 1:6rrs. I got 12.8@107mph with this combo. I whant more.
I heard good things about the cc306 cam?
With my hotcam I shift at 6000rpm. My engine builder says its cool to reeve more. But im chicken hahah.
Is the cc306 going to make power even higer up in the rpm band?
If I go with the 306cam, should I use 1:5rockers, or should I use my 1:6rockers. If I use 1:6rockers i need new valve springs.
Hope you can share som info on this..
thanks
Old Aug 15, 2005 | 10:30 PM
Default RE: A cam question.
You have a very stout engine and if everything was assembled properly, and BALANCED, it should be able to go to 7500 without any fear. Most of GM high perf cam are made by Crane and relabeled. Give Crane Cams a call, US country code +356-258-6174 or http://www.cranecams.com/ Tell them what you got and what you want to do and they can recommend one of their stock offerings or custom gring a cam to meet your needs. They will also advise on what springs to use. They will need to know your car weight (in lb.). final drive gear ratio, what transmission you are using ( auto or manual ), and all the mods you have done. Also, if you intend to start revving the engine up, you should replace the harmonic damper with one that is SFI approved, this is to protect innocent bystanders in case the damper decides to disintegrate. Also let them know what is the highest octane fuel you can find in your part of the world. Considering all the mods you did you should be runing in the low 12s at about 115. Some fine tuning of your computer is probably needed.
Pete
Old Aug 16, 2005 | 03:37 AM
Devilfish's Avatar
Thanks for your answer
I will give crane a call, nice tips
You right, i need some more tuning. The wideband 02 showed a 12.2 on my wot run. A bit to rich..
Its nice to know that you verify what my engine builder say, that with this engine i could reeve abow 6000rpm. I guess i just need to abuse it more
It got a new SFI approved damper..
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
