reg. maintenance
Old Jul 31, 2005 | 09:39 PM
deang423's Avatar
Default reg. maintenance
What is the best things to replace or check at 105,000 on a 96 Z.
thanks
Old Aug 13, 2005 | 09:36 PM
Default RE: reg. maintenance
grease tie rod ends, and lower ball joints
replace serpentine belt
replace engine coolant
check front wheel bearings for noise
replace transmission fluid and filter on automatics
replace spark plugs (this will teach u a lesson)
replace spark plug wires
change engine oil & filter
change fuel filter
change air cleaner
inspect brakes
inspect exhaust system
replace brake fluid
replace rear end fluid, use special additive for positraction
chck tires
align wheels
check for leaks
pmcculfor
Jun 7, 2012 06:50 AM
Bobaloo
May 3, 2012 11:19 AM
94Red
Jul 4, 2007 11:12 PM
twelvenine2001V6
Oct 7, 2006 06:48 PM
