Computer & Fuel Systems Talk about the control module, fuel systems and delivery, customization and more.
TunerCat Help
Old Feb 4, 2010 | 05:50 PM
JordanT's Avatar
Default TunerCat Help
I recently put a new cam in my camaro, had some light headwork done, and put headers on and I bought tunercat to tune it up. The only problem is that I do not really know what I need to change. I have played around with the program and have done a lot of research on it, but have not really found any good information about what to change and how to change it. Any help would be VERY appreciated. Thank you.
Old Feb 7, 2010 | 10:45 AM
JordanT's Avatar
No one?
Old Feb 7, 2010 | 01:26 PM
GMDCAMARO's Avatar
Year and Engine might help..
Old Feb 7, 2010 | 02:00 PM
z28pete's Avatar
Tech Droid
To start with, you should get a wide band O2 meter and see what the fuel mixture is at different load and RPM conditions before changing anything. In most cases the only thing you will need to do is to make changes for the WOT (open loop) state, the part throttle stuff will probably self adjust.
Old Feb 8, 2010 | 02:31 PM
JordanT's Avatar
It is a 1994 LT1 5.7 liter. It has a 268 grind cam I think from comp cams. The problem with an O2 meter is that they are pretty expensive from what little I have looked for them.
doww301
Jul 4, 2010 11:30 PM
JordanT
Apr 9, 2010 08:34 PM
JordanT
Mar 11, 2010 02:56 PM
