Camaro Forums - Photo Galleries - Create an Account - Chevrolet Camaro
Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > Camaro Models > 1st Generation
Reply
Thread Tools Search this Thread
Old 11-02-2009, 01:31 PM
Popkorn69 Popkorn69 is offline
Default Big block conversion 1969 camaro
Need some advice ... adding big block to 69 camaro ... I am aware of the motor frame mounts ... transmission cross member ... etc. What I am looking for at this point is some info on which water pump was used .. long or short ... I am assuming long due to the location of the alternator. In terms of power steering ... I am assuming the brackets changed a bit from SB to BB. I do need to replace my steering box as it is shot anyway ... should I just order a complete kit ... or will some of the existing parts work? In terms of the heater core ... I have heard you can still use the same box ... but modifications are needed ... I am assuming I would need to buy the separate heater core ... Help!!!
UPDATE::
It looks as though the short water pump was on the 67 and 68 models .. for 69 I am about 99% sure I need the long water pump and correct brackets to keep the alternator on the passenger side. Powerstering pump appears to be different ... has anyone eliminated power steering and gone back to a manual box ... is it a direct bolt in item??
This ad is not displayed to registered members.Register your free account today and become a member on CamaroForums!
Last edited by Popkorn69; 11-03-2009 at 03:56 PM. Reason: Figured out a few things few new questions
Old 11-07-2009, 07:35 AM
P51man P51man is offline
I have a factory big block, so I can't comment on the swap, but I'm sure your right about the alternator. My car has the long pump, and the alternator bolts to it.
Old 11-09-2009, 01:09 PM
Thanks .. that does help!!
Old 11-11-2009, 12:15 PM
1969 SS's Avatar
1969 SS 1969 SS is offline
first off, small block frame mounts WILL work with the big block. the only thing this does, is it puts the engine a bit farther back to the firewall (no big deal there) and it also puts it a bit closer to the steering box and that's not really an issue unless you are using big tube headers. even if you do use big tube headers with this combo, just buy Hooker Comps (not Super Comps because they don't fit with P.S.) and dimple the #3 tube.
you will also just have to elongate the holes for your tranny crossmember becuase it will also be slightly back (again, no big deal)
your steering box is the same. you will be using a long waterpump. accessory brackets are all different.
the heater core is probably the biggest change. the SB and BB use the same heater box firewall cover but the BB one has holes drilled in a different location to accept the BB heater core. they holes are different to allow for the girth of the BB. you can use your original box and just drill holes for the new BB heatercore, and then you can buy the parts needed to seal it. (this will save you around $100.00).
the only thing you will need to do after this, is to fill the holes in the firewall where the old heater hoses came through
hope this helps out
__________________
________________________________________
I just try to do, what I can do, when I can do it
http://www.northeastrodrun.com
http://www.myspace.com/northeast_rod_run
Old 11-11-2009, 02:12 PM
Y2K's Avatar
Y2K Y2K is offline
Quote:
That's exactly how I did mine including the dimple in the headers although they weren't Hookers,been 30 years ago but I think the brand was Prostock or something like that,anyhow it worked the same.
I did run into one minor issue,I was running an Accel dual point dizzy with a cable drive tach and sometimes when I'd bang a gear real hard the motor would torque over enough that the dizzy cap hit on the firewall and got cracked.
I fixed that by pulling the dizzy out and doing a little hammer work on the firewall.
Of course that way back when a '69 Camaro was just another Chevy not a gold plated piece of exotica.
Anyway,most people run an HEI these days,might have the same problem as they have a pretty big cap.
__________________
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Reply
Tags
1968, 1969, 67, 69, alternator, bb, big, block, camaro, chevy, conversion, firebird, firewall, hei, modification, sb, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
