Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Vendor Threads | New Picture Comments | New Profile Comments |
Search:
Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > Drivetrain Tech > Nitrous, Super Chargers, & Turbos
Sign in using an external account
Register Forgot Password?
Reply
LinkBack Thread Tools Search this Thread
Old 12-04-2007, 08:45 PM
No cars in keithp7630's garage, add now
Default twin turbo third gen???
i am wondering what kind of fuel system add on should i use on my 350 tpi twin turbo set up. what can i do to the computer of the car to have it know when to give it more fuel when the boost levels get higher, so it doesnt not get enough fuel and detonate. is there a special prom?
does anyone have a turbo timer
Old 12-04-2007, 09:00 PM
SpecterGT260's Avatar
Ninja Administrator
1998 Pontiac Trans Am
Default RE: twin turbo third gen???
do you already have this setup? Really all you would need is a better fuel pump, and bigger injectors, depending on the amount of boost you plan to run. as far asthe computer goes not sure how they tune one of those. the stock computer should have the ability to handle TT, assuming it gets the proper tune. Not sure though.
__________________
Congratulations! OT has officially gone Days without a stupid comment!
Old 12-25-2007, 05:06 PM
do you thinkthat a 9-1 compression ratio or maybe a little more is good enough or should i drop the compression ratio to 8-5-1
Old 12-27-2007, 02:38 PM
cbr600rx7's Avatar
No cars in cbr600rx7's garage, add now
As said above injecters and a good pump are all you need maybe not injecters if you are running low boost. 5PSI or lower. You should be good with 9.1. How big are the compressors and how much boost are you planing on running. Tuningand working withthe timingshould also be at the top of your list.
__________________
CHEAP, FAST, RELIABLE YOU CAN ONLY PICK TWO
2000 WS6 TTI T76 turbo,, RPM stage 5 4L60, Mosor 12 bolt, 524 rwhp/499tq
2001 WS6 409ci LQ9 Iron Block. 11.3 compression. 243/251 cam, 9 inch, T56,
Activity Stream
Search:
Reply
Tags
350, 3rd, camaro, firebird, fuel, gen, pump, run, set, setup, thirdgen, tpi, turbo, turbocharger, twin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
