Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Vendor Threads | New Picture Comments | New Profile Comments |
Search:
Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > Drivetrain Tech > Nitrous, Super Chargers, & Turbos
Sign in using an external account
Register Forgot Password?
Reply
LinkBack Thread Tools Search this Thread
Old 01-09-2008, 05:16 AM
No cars in Twizted96Camaro's garage, add now
Send a message via AIM to Twizted96Camaro
Default single turbo set up
was wondering if turboing a v8 is same as a 4 banger? how much boost can a stock lt1 350 handle without changing any thing and were can i find turbo parts for a camaro??
Old 01-09-2008, 10:05 AM
No cars in ninetysixyenko's garage, add now
Send a message via AIM to ninetysixyenko
Default RE: single turbo set up
i beleave it's around 7-9 PSI on stock internals. and for that much boost, prolly better getting a procharger, you can bolt it on yourself, then just get it tuned.
__________________
DC-Sport Header Back Exhaust, Injen SRI, AEM Under Drive Pulleys, B&M Short-Throw, Big Brake Kit, Torque Dampener.
5% Tint All Around, Halo's
Old 01-09-2008, 11:04 AM
No cars in badinfluenceRS's garage, add now
Send a message via AIM to badinfluenceRS
www.camaroz28.com has a sponsor that makes kits for pretty reasonable
__________________
'96 RS
'00 R1
'07 Impala
'86 K10
Old 01-09-2008, 05:33 PM
cbr600rx7's Avatar
No cars in cbr600rx7's garage, add now
It depends a little bit on what kind of set up you want to run. Boost vs. compressor size also matters on how much boost you can run safe. The basic principles are the same for any gas engine the only thing that changes is how you chose to run and tune the set up. STS makes good affordable systems for the Fbody. The amount of boost you can run willalso depend on if you’re running an Intercooler, fuel mods, and how much tuning you want to but into the set up. I strongly recommend having the LT1 dyno tuned for even low boost. It will make the engine run more efficient and can save you lots of pain latter on.
__________________
CHEAP, FAST, RELIABLE YOU CAN ONLY PICK TWO
2000 WS6 TTI T76 turbo,, RPM stage 5 4L60, Mosor 12 bolt, 524 rwhp/499tq
2001 WS6 409ci LQ9 Iron Block. 11.3 compression. 243/251 cam, 9 inch, T56,
Old 01-11-2008, 02:40 AM
thanks i just wanted to run low boost like shootin a 50 shot of nitrous but i can control the boost an i dont have to keep buy nitrous all the time... 5 to 7 pounds boost something noticeable but not crazy but thanks on the info man
Old 01-11-2008, 09:09 PM
cbr600rx7's Avatar
You can notice as little as one pound of boost on a mild size turbo. It might not throw in back into the seat but it would add some performance. Running 7 pounds would be as far as I would push it if you don’t plan on running an intercooler. I would strongly suggest dyno tuning for any thing over 5 pounds. It would be a good idea to upgrade your fuel pump just to be on the safe side of things as well.
Turbo’s make power based on a few things the first being boost pressure. Obi sly the more boosts you run the more air your pushing into the engine. The second factor is the size of the turbo it’s self. A large turbo may move more air at a lower boost level vs. a smaller one but could take longer so spool and build pressure. The remaining factor is intake tempter. Turbo’s produce a lot of heat and as a result they cause large increases in intake charge tempters. Tempter increase more as you increase boost. If the temps get to hot it can lead to knocking and even detonation and heavy engine damage this is ware intercoolers come into play. However A large intercooler may increase cooling but can also increase lag as well plus they are not cheap as you well know.
Most v8s run a good size turbo vs. are 4 cylinder friends. Just because a turbo isntrunning 18 pounds of boost doesn’t mean they are not making good power. STS claims a 120 horse power at the wheels increase on there none intercooler system at only 7 pounds of boost on the LT1 kit using a T04E 60-1 Garrett turbo and claim a 1.3 second increase in the 1/4. There LS1 kits claims 100 HP at only 5 pounds also none intercooler
__________________
Activity Stream
Search:
Reply
Tags
350, 601, boost, camaro, chevy, garrett, handle, kit, kits, ls1, setup, single, stock, turbo, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
