Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
Which power maker should I use
Old Jun 16, 2007 | 11:03 AM
riceeater's Avatar
Default Which power maker should I use
I want to know which way I should go with my camaro. its a '71 and has a beefed up 307 right now. I have a 350 4 bolt motor and want to know what I should do
Old Jun 16, 2007 | 11:40 PM
nickdotcom's Avatar
Default RE: Which power maker should I use
it depends on what it was built for...
Old Jun 23, 2007 | 07:34 AM
VQMaxFan's Avatar
What kind of H.P. do you want to achive?
What kind of compression are you going to build the motor to N/A?
What Kind of racing are you going to be doing?
What kind of powerband do you want?
On a carburated car i would not suggest turbocharging.
Old Jun 25, 2007 | 06:38 PM
z28 john's Avatar
Yeah! The problem with supercharging a carbureted/throttle-bodied engine is that you have to get the air-charge UNDER the fuel-source, since it's nearly impossible to seal it to the top of it!
Better decide what all you intend to change (like, I'd dump the 'lazy' 307- quick!) before you start trying to decide on a forced-induction method!
John
Old Jun 27, 2007 | 03:31 PM
riceeater's Avatar
the lazy 307 runs low 14s, I wanna get into the 12s an I have a 350 block I am doin this on as for compression, I have not rebuilt the motor, so obviosly low compression for forced induction, around 10.5:1 otherwise. Also, my uncle has been building motors for years an has built 3 turboed carb motors, I would get his help in that situation.
Old Jun 27, 2007 | 07:25 PM
nickdotcom's Avatar
i was under the impression that the engine was already built, my mistake.
nitrous 100%
by far the best bang for the buck
Old Jun 28, 2007 | 09:21 PM
riceeater's Avatar
yeaH, i feel the same way, but I got the chance to ride in a Lingenfelter vette a couple weeks ago (the body shop I work at tinted his glass) an turbos on that car are amazing, of course anything I do cant equal that but I was def impressed
Old Jul 15, 2007 | 04:03 PM
1985RS's Avatar
if you plan on force inducting it, DO NOT go 10.5:1 compression, you will either destroy the engine, or if your are running really low boost, you will have horrible fuel ping. try for around 8.5:1. 10.5:1 compression is barely able to run on premium pump gas. not suitable for boost. unless you plan on running say, nitro fuel or something ridiculous like that lol
Old Jul 17, 2007 | 09:22 PM
riceeater's Avatar
obviously i would keep compression low if i blow, around 8:1 or 7.5
Old Jul 18, 2007 | 11:26 AM
1985RS's Avatar
my bad, misread your post[&:]
