Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Vendor Threads | New Picture Comments | New Profile Comments |
Search:
Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > Drivetrain Tech > Nitrous, Super Chargers, & Turbos
Sign in using an external account
Register Forgot Password?
Reply
LinkBack Thread Tools Search this Thread
Old 06-16-2007, 11:03 AM
No cars in riceeater's garage, add now
Default Which power maker should I use
I want to know which way I should go with my camaro. its a '71 and has a beefed up 307 right now. I have a 350 4 bolt motor and want to know what I should do
__________________
1971 Camaro RS
400 Small Block
M22 4-Speed
3.73 Posi Rear
Old 06-16-2007, 11:40 PM
No cars in nickdotcom's garage, add now
Default RE: Which power maker should I use
it depends on what it was built for...
__________________
Old 06-23-2007, 07:34 AM
No cars in VQMaxFan's garage, add now
What kind of H.P. do you want to achive?
What kind of compression are you going to build the motor to N/A?
What Kind of racing are you going to be doing?
What kind of powerband do you want?
On a carburated car i would not suggest turbocharging.
__________________
85' Project Car in need of a new motor
Daily Grind lightly modded 2k maxi-pad
Old 06-25-2007, 06:38 PM
No cars in z28 john's garage, add now
Yeah! The problem with supercharging a carbureted/throttle-bodied engine is that you have to get the air-charge UNDER the fuel-source, since it's nearly impossible to seal it to the top of it!
Better decide what all you intend to change (like, I'd dump the 'lazy' 307- quick!) before you start trying to decide on a forced-induction method!
John
__________________
Two '94 LT1 Z's: one convertible, one super-charged coupe
Old 06-27-2007, 03:31 PM
the lazy 307 runs low 14s, I wanna get into the 12s an I have a 350 block I am doin this on as for compression, I have not rebuilt the motor, so obviosly low compression for forced induction, around 10.5:1 otherwise. Also, my uncle has been building motors for years an has built 3 turboed carb motors, I would get his help in that situation.
__________________
1971 Camaro RS
400 Small Block
M22 4-Speed
3.73 Posi Rear
Old 06-27-2007, 07:25 PM
i was under the impression that the engine was already built, my mistake.
nitrous 100%
by far the best bang for the buck
__________________
Old 06-28-2007, 09:21 PM
yeaH, i feel the same way, but I got the chance to ride in a Lingenfelter vette a couple weeks ago (the body shop I work at tinted his glass) an turbos on that car are amazing, of course anything I do cant equal that but I was def impressed
__________________
1971 Camaro RS
400 Small Block
M22 4-Speed
3.73 Posi Rear
Old 07-15-2007, 04:03 PM
No cars in 1985RS's garage, add now
if you plan on force inducting it, DO NOT go 10.5:1 compression, you will either destroy the engine, or if your are running really low boost, you will have horrible fuel ping. try for around 8.5:1. 10.5:1 compression is barely able to run on premium pump gas. not suitable for boost. unless you plan on running say, nitro fuel or something ridiculous like that lol
__________________
Theres no replacement for displacement
-1986 Camaro Sport coupe
-a goodies list as tall as you
Old 07-17-2007, 09:22 PM
obviously i would keep compression low if i blow, around 8:1 or 7.5
__________________
1971 Camaro RS
400 Small Block
M22 4-Speed
3.73 Posi Rear
Old 07-18-2007, 11:26 AM
my bad, misread your post[&:]
__________________
Activity Stream
Search:
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
