Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Vendor Threads | New Picture Comments | New Profile Comments |
Search:
Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > Drivetrain Tech > Nitrous, Super Chargers, & Turbos
Sign in using an external account
Register Forgot Password?
Reply
LinkBack Thread Tools Search this Thread
Old 12-19-2006, 01:26 AM
No cars in hotrodguy1986's garage, add now
Default nitrous and hyperutectic pistons
i know it isn't much but how much can hyperutectic pistons handle when it comes to nos in a sbc 355
__________________
its never to fast
Old 12-20-2006, 09:57 AM
No cars in 6292Z28's garage, add now
Default RE: nitrous and hyperutectic pistons
I can tell you that we had a 1989 IROC that we sprayed 150 shot on for about 3 1/2 years of racing, ( approx. 80 bottles) with no damage to the pistons. We never tryed any more than that, so I really can't entirely answer your question. I do know that when a hyperutectic piston reaches its failure point it disentigrates into very small pieces all at once unlike a cast or forged piston that will crack or break into chunks.
__________________
1983 Z28 11.75 @ 117.19 1.62 60'
s/c, trick flow heads,1 3/4 super comps, 3400 stall, k-member & arms, full frame rails, torque arm, 3 " exhaust, rack, moser 12 bolt, 3:73, cell fuel system, new nitrous kit, 6 point bar, et streets
Old 12-20-2006, 12:41 PM
No cars in rat454's garage, add now
You might try the below link some of the tech articles might be helpful...
http://www.kb-silvolite.com/index2.php
Greg
__________________
71 Camaro roller cam 454 LS6 tremec TKO 600 5 speed 2.56 gears,t-top, New Mexico plate "RAT454"
74 Monte Carlo 95 LT1 drive train swap, full computer
77 C10 short step 4x2 454 T-400 hugger orange 496 rwtq
67 Buick Electra 225, 430 tire burner
Old 12-20-2006, 01:26 PM
thanks for the help guys so you say you had hyperutectic pistons for three years and never had a problem somebody told me all i had to do was increase the top ring gap to .033 does this sound about right to you guys like i said i know my way around a small block i just never used nos before
__________________
its never to fast
Old 12-20-2006, 07:28 PM
The 89 car ran a nos wet plate kit and we used a second fuel pump that came in when the nitrous was activated. The short block was stock, (never even had it out of the car). As long as you run them a little fat on the fuel tune and keep your timing conservative the hyperutectics will live
__________________
Old 12-21-2006, 05:34 PM
No cars in reallyoldguy's garage, add now
do any of you think that a 150nitrous sys. that basicly is just for looks ( meaning used only once in a while) in a 355cid , 4340 fordged crank /recond.stock rods, S.P. Hyper.pistons Clevit -H bearings is worth the cost and since most here are O.K. with Nitrous and hyper pistons.
Engine is built ,looking hard at NOS?
thanks y'all
__________________
cars since 1956
Old 12-21-2006, 05:54 PM
No cars in shnormo's garage, add now
Send a message via AIM to shnormo
You do want a slightly larger ring gap withforced air inductionand or nitrous. It will create more blowby, but when everything is superheated, it will expand and seal better.
Quote:
ORIGINAL: hotrodguy1986
__________________
- Norm
http://www.cardomain.com/id/shnormo05
Rebuilding 79 Camaro
Old 12-21-2006, 10:55 PM
bigger ring gap? OK if the ring gap the std. .30 over you get with a new set of pistons??
and we only use the lower setting, on the nitous kit 75,125 ,150, 200 hp
my real goal is to build this Camaro for wife, daughter,granddaughter
I know this sounds a little silly, but thats the deal. want a good running Camaro that
can be pumped up when they want show off a little.other then that going over the whole car ground up am not looking huge horsepower out of the 355 -fordged crank,recond. steel rods , S.P. Hyperu. pistons ClevitH bearings,steel roller rockers 1.52.1,Crane 4340 push
rods, 268h Comp.Cam -hi-po lifters,, gear drive time, two timing cover,Milling Z28 oilpump, oil panis a kick out baffels and trap door 71/2"Qt.,GM windage tray,block is aline honed deckedand race prepped. using chevy 487x 2.02 heads with guides, screw in studs& polylocks . Air gap intake & Holly S/A 670 carb. brass freeze plugs and pipe tap oil gallery plugs NOW with all thatcan I use the nitrous 125 HP set up
thanks ,reallyoldguy
__________________
cars since 1956
Old 12-21-2006, 11:28 PM
No cars in z28pete's garage, add now
If the pistons are 30 over you need rings that are also 30 over. The ring gap should always be checked before assembly as the last thing you need is for the rings to expand enough to bind and damage the pistons and cylider wall. The nitrous will generate a lot more heat and pressure inside the cylinder, and all the extra heat and pressure hits the top ring. As Norman mentioned, the top ring gap should be set around 0.030" bigger than normal to allow for the extra expansion. The blowby will not be that bad if the rings are installed and the gaps staggered properly.
__________________
Pete
Old 12-23-2006, 08:46 PM
z28pete, the sealed power pistons came as a set pistoms are the coated ones and the ring set thatcame in thebox, these pistons are .30 over as are the rings -do we now pull the pistons and file the rings to a larger gap ?- guys understand i'm new to nitrous. I worked as a GM mach. in dealerships for years. and raced back in the 60s-70's but out of cars for many years.
I do know my way around a wrench on them old cars. and this78 Camaro has been in the barn since 1983. Idid most ofengine building onour race team . but sure as monkeys live
trees. engine building has gone right by doing 90mph.
so can understand what you guys are saying -just a little slow in the old brain pan???
need all the HELP I can get
Thanks, reallyoldguy
__________________
cars since 1956
Activity Stream
Search:
Reply
Tags
355, 487x, 496, 79, block, camaro, chevy, gap, heads, nitrous, plate, ring, sbc, small, wet
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
