Activity Stream: Show All | New Threads | New Posts | New Pictures | Popular Threads | Lonely Threads | Vendor Threads | New Picture Comments | New Profile Comments |
Search:
Go Back   Camaro Forums - Chevy Camaro Enthusiast Forum > Drivetrain Tech > Nitrous, Super Chargers, & Turbos
Sign in using an external account
Register Forgot Password?
Reply
LinkBack Thread Tools Search this Thread
Old 06-14-2011, 07:22 AM
ncxmod355's Avatar
No cars in ncxmod355's garage, add now
Default dry nitrous system
will a 50 hp dry nitrous system work on a 92 3.1 v6
will the ecu put the needed fuel for it to work or are there
something that needs to be done first
any info will help
__________________
1992 25th anniversary rs camaro
Old 06-14-2011, 08:46 AM
Cheeks's Avatar
August 2011 ROTM
2000 Chevrolet Camaro
Cheeks240sx
Send a message via AIM to Cheeks
any info will help
it will "work". The stock ecu isn't going to add any more fuel in there without it be told to. Depending on the motor it should handle a 50 shot no problem, but it never hurts to add a little more fuel before you spray. Turning up the fuel pressure was always a way we put a bandaid on teh problem, although I wouldn't do it often.
__________________
Thanks To:
First Try Engineering
Induction Solutions Nitrous
HoleShot Wheels
HiTech Tuning
QA1
AMS Nitrous Control
Mickey Thompson Tires
10.42@131 - 275 DR
Old 06-26-2011, 01:13 PM
cbr600rx7's Avatar
No cars in cbr600rx7's garage, add now
Your set up will not add fuel with out being told to do so and thats kind of hard on a 3.1 ecu. However there is luck for your. For some reason the old iron 2.8 and 3.1 motors do like nitrous. You should be fine with a 50 dry shoot (should be) but why not play it safe and add a wet nozzle. You would also have the option to steep up to a bigger shoot in the future.
__________________
CHEAP, FAST, RELIABLE YOU CAN ONLY PICK TWO
2000 WS6 TTI T76 turbo,, RPM stage 5 4L60, Mosor 12 bolt, 524 rwhp/499tq
2001 WS6 409ci LQ9 Iron Block. 11.3 compression. 243/251 cam, 9 inch, T56,
Activity Stream
Search:
Reply
Tags
2011, 50hp, camaro, dry, install, jetting, kit, lq9, nitrous, nos, sbc, stock, system, v6, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Emails Backup
