What to do, cant get my water pump off!! - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 01-20-2008, 04:35 PM
Default What to do, cant get my water pump off!!
Can anyone please explain to me how to get the water pump off of my 94 z28? I cant get the bolt behind the power steering pulley off. i tried looking to see how to get the p/s pump off but that was hopeless. any suggestions?
Old 01-20-2008, 04:41 PM
Default RE: What to do, cant get my water pump off!!
uugh i dont really know, buya haynes book for your car, i've heard that they are a real pain to fix but buy the book and you should be fine
Old 01-20-2008, 04:43 PM
jus thinking about it, can you get to it by taking the power steering bracket off? it's only 2 bolts
Old 01-20-2008, 11:10 PM
i found one of the bracket bolts. the one behind the p/s pump. where's the other bracket bolt at?
Old 01-20-2008, 11:42 PM
Its kinda hard to get to but you have to use an extention and a short socket. If you can try to find a skinny extension so you can fit it in between better.
Mines a 95 so I dont know if there is much a difference.
Old 01-21-2008, 12:42 AM
SpecterGT260's Avatar
Ninja Administrator
can u get on the bolt at all? just crank it until it hits the pulley. by that time it should be out of the block, while still inside the pump. but the pump will be free but sealed onto the block. a couple good yanks (or taps witha malet like I did) and it will come off. dunno if this works for lt1, but just a thought
Old 01-21-2008, 06:03 PM
thanks for yalls input. it helped out alot. one last ? though. how do i get the a/c compressor pulley and clutch off? i need to change the clutch bearing and last time i tried it, the tools i rented didn't work. when i put the first tool on, all it did was spin even when i had the accesory belt holding the pulley still. so needless to say i never even got to the next step with the pulley tool.
Old 01-21-2008, 06:05 PM
did i skip a step?
Old 01-27-2008, 02:44 AM
If you already got your pump off, then sorry for posting late. There are six bolts total, the hardest one is the one behind the power steering pump. You don't need to take that off, what I did was I used a swivel-head extension. Also try putting the socket onto the bolt and then stick the wrench and extension onto the socket, that worked for me. I'n my car I had to remove my air pump and bracket to get the right side middle bolt off, don't know if you'll have to do the same.
Old 01-27-2008, 07:57 AM
Ninja Administrator
his engine has a different pulley configuration. chances are he got the bolts but the gasket was just fused.
Reply
Thread Thread Starter Forum Replies Last Post
Water pump. VALHAR LT1/LT4 Tech 0 12-04-2010 11:51 PM
Which water pump to use? cadmanof50s 67-69 General 4 09-22-2010 08:38 PM
water pump imcdowel LT1/LT4 Tech 15 05-08-2010 10:13 PM
water pump camarorz28 LT1/LT4 Tech 5 01-27-2008 02:57 AM
Tags
1994, 1997, 94, ac, braket, camaro, delete, gm, lt1, power, pulley, pump, rs, steering, water, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
