Trying to find the oil pressure senor 1994 Lt1
#24
it should bottom out agaainst the screw coming out of the tb. it should hit against the bent flat part. the bend should be square. it may be its been bent. make sure when its set that the tb butterflies are not closed all the way, they will stick if they touch the tb throat or inner part of the openings. you want it just barely open when closed. you can move the screw part using a allen wrench in the opening on the opposite side. some are plugged and you have to open the hole. i just used some needle nose to screw it in and out or just bent the flat part,,, lol
