LT1/LT4 Tech 1993-1997
Trying to find the oil pressure senor 1994 Lt1
Old 10-25-2016, 11:32 AM
Blackbox19's Avatar
The FSM may have the throttle pic,, and I can say I tried my best to find it... But I could not..
I saw a video that showed the stop on the top bolt... But when I tried that it dont hit the throttle at all..
  #22
Old 10-25-2016, 01:09 PM
this has some views starting about 1 minute into it.
  #23
Old 10-25-2016, 04:22 PM
Blackbox19's Avatar
That was video I saw... It shows the stop on the top bolt... Even in the video the thottle does not hit the stop.... So that is wrong...
  #24
Old 10-25-2016, 06:25 PM
it should bottom out agaainst the screw coming out of the tb. it should hit against the bent flat part. the bend should be square. it may be its been bent. make sure when its set that the tb butterflies are not closed all the way, they will stick if they touch the tb throat or inner part of the openings. you want it just barely open when closed. you can move the screw part using a allen wrench in the opening on the opposite side. some are plugged and you have to open the hole. i just used some needle nose to screw it in and out or just bent the flat part,,, lol
James Mcclelland
02-18-2014 04:18 PM
1994btandoz
02-12-2011 09:24 PM
cgalle
67-69 V8 Tech
06-13-2009 10:06 AM
samtron
06-22-2008 01:18 PM
FlufyTiger
11-13-2006 09:55 PM
Quick Reply: Trying to find the oil pressure senor 1994 Lt1
