Transmissions that will fit my 93 z28
i would think 93-97 trans will bolt up, but i think with 93-94 maros, they were 4l60. newer trans are 4l60e. same trans but the e=electronic. i can check for you tmrw when i go to class. im a GM ASEP student and ironically enough im in GM automatic trans class right now lol
1993 is the only year with no modifications. It was the only year for the 4l60 trans and it is what you have. Earlier years of the 700r4 will fit but must be modified. I think the tail shaft housing and your electrical plug are a couple of the things that have to be changed be I'm not sure what else. So a 86-93 trans could possibly be used. '94 up are 4l60e's and cannot be used unless you buy a separate trans controller that cost like $1500.
