LT1/LT4 Tech 1993-1997
Transmission compatability
Old 02-08-2009, 06:08 PM
ramsey041587's Avatar
Default Transmission compatability
I have a 97 camaro z28,transmission is totalled. So I got one out of a van looks identical to it thing is the sensor is on the driver side instead of the passenger. Is there a certain model or year that the tailhousing needs to come out of.Do you think this transmission will work(has w30 stamped on it)4l60e,minus the tailhousing.
Old 02-08-2009, 06:23 PM
rondavis's Avatar
well a 4l60e is a 4l60e it should work you might be able to use the tail housing off of your original and put it on the new one
Old 02-08-2009, 06:28 PM
Mine was in pieces.I found one in a junk yard but the sensor was on the opposite side.Are there a few other vehicles that have the same tail housing?
Rammsteinteufel9
Modification
11-02-2014 09:40 PM
resurrect
03-13-2011 11:09 PM
MelloYello
01-10-2011 07:07 AM
Massey
08-01-2010 08:08 PM
80RSchik
05-18-2006 11:25 PM
Quick Reply: Transmission compatability
