LT1/LT4 Tech 1993-1997
throttle bodies
Old 02-14-2009, 11:41 AM
blazelt1's Avatar
Question throttle bodies
before i start my question i would like to say thanks to everyone who replies back its much aprectiated. now i need to grab a throtle body ive seen the lets say factory ones that are ported to 52mm or the 58mm. are these better than lets say a bbk or hollie ive seen on them that the linkages were alittle loose and i wonder if the ported factory one wont have that problem.
Old 02-14-2009, 11:50 AM
cbr600rx7's Avatar
No a aftermarket TB would be your best bet for getting the most flow. Both are good brands and fitment should not be a issue. I am sure one of the senior LT1 guys will drop in and give you more info and details.
Old 02-14-2009, 11:51 AM
Saint_Ali's Avatar
its pretty much the same as aftermarket, they are ported to flow more
Old 02-14-2009, 12:39 PM
95slvrZ28's Avatar
You can get up to 54mm on the stock intake, if you go for the 58mm you're going to need to get the intake ported as well. That said, do you need a new TB, or are you purchasing one for a performance upgrade? You're really not going to get much, if any power out of a new TB until you have some internal work done to the car.
Old 02-17-2009, 01:43 PM
blazelt1's Avatar
the motor that is goin in allready has internals and the intake mainifold is allready ported
Old 02-17-2009, 04:36 PM
95slvrZ28's Avatar
In that case you'll probably want to go for a 58mm TB, whether that be a ported stock TB or an aftermarket one you'll probably get similar flow out of both. Depending on how much power you think you'll be making you may want to consider larger injectors (33#) as well.
Old 02-17-2009, 04:46 PM
whammer3024's Avatar
ROTM Winner
does the motor have ported heads?
Old 02-18-2009, 12:29 PM
blazelt1's Avatar
this is what i got and plain on doin i bought the motor out of 96 impala it was a 355 lt1 super charged. i did not by the blower with it. fortunetly for my the guy never put low compression pistons in it just had taller head gaskets. the cam is a mildly aggressive cam i got the specs some were got to look for them intake mainifold was ported to fit his 58 mm throttle body so there was no restriction. now i thought the 58mm would be to much air flow for a naturley aspirated motor so i was goin to go with the 52mm and 30# injectors
Old 02-18-2009, 12:59 PM
blazelt1's Avatar
and i forgot to add it has trick flow heads with 1:7 rocker ratio
Old 02-18-2009, 01:09 PM
ROTM Winner
if its been opened for a 58mm then get a 58mm...30# SVO injectors should be enough
Quick Reply: throttle bodies
