LT1/LT4 Tech 1993-1997
Spark plugs and wires
Old 04-10-2011, 07:44 PM
greenmachine96's Avatar
Default Spark plugs and wires
Im goin to do the plugs and wires this weekend and have been reading different procedures from different sources. I was wondering If all I should have to remove is the starter and alternator to do this?
Old 04-11-2011, 12:07 PM
removing alt and starter should make the job way easier on the passenger side. i did mine when i was replacing the opti and having the water pump outa the way was nice but not necessary.
Old 04-11-2011, 12:56 PM
torque_is_good's Avatar
drivers side can all be reached easily from above.
Passenger side #6 and #8 are the tough ones but #6 the hardest.
For #8 you will need to lay horizontally across your engine and reach in between the header tubes but you get to it that way. I found #6 was easier from below. Just put a 5/8 socket on the plug and use an open end wrench. It also fits in between your header pipe.
With a service lift you can swap plugs and wires in under an hour.
Without a service lift i figure you add about 20 minutes contorting to get to #6
With stock exhaust manifolds I can't answer.
Old 04-11-2011, 01:01 PM
If i decide to wait until next week I may have access to a lift so thats should ,like you said, make it a little bit easier.
Old 04-11-2011, 05:56 PM
How do you get to the plug wires on the distributor cap, from underneath?
Old 04-11-2011, 08:55 PM
yes coil wire from top.
talaboy1992
82-92 V8 Tech
07-02-2011 06:02 PM
C4r1b0u
01-15-2011 10:39 AM
kidd75
67-69 V8 Tech
12-01-2010 02:48 PM
CaosCamaro
05-15-2009 01:42 PM
Quick Reply: Spark plugs and wires
