removing gas tank - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 08-22-2006, 01:35 PM
Default removing gas tank
do you have to drop the diff to reach it and what do you think a shop would charge to do this.
Old 08-24-2006, 12:30 AM
Default RE: removing gas tank
The rear end has to be dropped to remove the tank.
Old 08-26-2006, 10:36 PM
IF YOU ARE REMOVING THE TANK TO REPLACE THE PUMP IT IS EASIER TO CUT AN ACCESS DOOR UNDER THE REAR HATCH CARPET. THATS WHAT I DID EVEN PUT A HINGE ON THE PIECE I CUT OUT FOR EASY FUTURE ACCESS
Old 08-27-2006, 02:18 PM
That is what most shops usually do, but leave the hinge out and still charge you for dropping the axle. Some manufacturers had the foretought of building the trap door into the car. Have you had any problems with water spalshing up thrugh the opening?
Old 08-28-2006, 05:58 AM
The rear end DOES NOT have to come out. All you have to do is drop the exhaust.
I have done loads of them. The older 86-92's are a little easier IMHO.
Old 05-06-2009, 12:59 PM
Lightbulb Trap Door Fuel Pump Replace- Convertible
This is with a convertible. A non vert will be much easier to and faster to do.
Good luck!
Old 05-06-2009, 03:19 PM
importmd's Avatar
I did the trap door on mine. its very easy. i made a plate larger than the hole and used some silicone to seal it, so if i want to open it up later i could peel the plate right back up.
http://www.geocities.com/formulapower2/fuelpump.html
Reply
Thread Thread Starter Forum Replies Last Post
gas tank EagleRex LT1/LT4 Tech 10 07-31-2010 11:50 AM
removing gas from the tank... xpbr2000 93-02 General 9 05-06-2010 05:04 PM
New gas tank kats69 67-69 General 6 07-02-2009 11:34 PM
Gas Tank ? Danscamaro02SS 93-02 General 3 07-24-2007 04:32 PM
Removing the fuel tank sante65 82-92 General 4 03-28-2007 04:32 PM
Tags
1979, 1992, 91, 92, 93, access, camaro, door, drop, dropping, firebird, fuel, gas, pump, remove, removin, replace, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
