LT1/LT4 Tech 1993-1997
4th gen v.s. 5th gen
Old 10-19-2011, 10:31 PM
Cliff123454321's Avatar
Default 4th gen v.s. 5th gen
Who would win between a bone stock 2011 camaro ss and a
1994 z28 with:
CRS electric water pump
All MSD ignition
Headers to straight 3" borla adjustable exhaust
Bored throttle body ns mass sensor with cold air intake
Transpak shift kit (strip)
stronger rear end alloy axel
Tubulor control arms with adjustable panhard bar
and a few other mods I'm probably forgetting
Old 10-19-2011, 10:35 PM
Cheeks's Avatar
August 2011 ROTM
who knows, too many variables. Go to the track and find out
Old 10-19-2011, 11:09 PM
The 2011 is standard and the 94 is automatic with a shift kit
Old 10-19-2011, 11:15 PM
Failed Devices's Avatar
5th gen.
Old 10-20-2011, 12:43 AM
MaVeN's Avatar
5th gen...
Old 10-20-2011, 10:12 AM
torque_is_good's Avatar
with drag radials on both, if the SS is a manny tranny, you'll be looking at tail lights after 300 feet. If you let the guy with the 5th gen make a few passes and get his launch dow pat and tire pressure dialed in, the only way you won't see tail lights the entire time is if he can't shift
Old 10-20-2011, 04:26 PM
Even with the shift kit? It's a strip shift kit and tires squeal from first to second everytime and when i'm flooring it, it squeals on every shift
Old 10-20-2011, 06:06 PM
you need at least a stall/gears to be able to hang. chirping tires is nothing new, a manual will do that no problem.
Old 10-20-2011, 06:30 PM
Well what else can I do to make my car be able to go up against the new camaros
and as my car is now, up to what year mustang gt could I beat?
Old 10-20-2011, 06:31 PM
Cheeks's Avatar
August 2011 ROTM
DUDE
enough bench racing. Go to the track and run it and I bet you'll see what you can/can't beat
otherwise, spray the ***** off of it
