LT1/LT4 Tech 1993-1997
Radiator Cap
Old 11-17-2012, 09:46 PM
jkeaton's Avatar
Default Radiator Cap
A couple of months ago I got one of those radiator caps with the lever to vent pressure off. It is an 18 psi cap. A couple of times recently when I get home, I hear gurgling and the radiator expansion tank will start overflowing. Not all the time, did it once a few weeks ago and again today. Temp gauge never shows an overheating condition, car is running fine. You think those caps are no good? Should I just get a regular radiator cap instead? Last, is 18 PSI the correct pressure cap for the LT1? FYI, last time it did it, I checked the level in the radiator the next day and it was fine, so whatever it boiled out, it sucked back in the refill the radiator, it just overflowed the expansion tank when it was bubbling out.
Old 11-17-2012, 10:02 PM
try bleeding it and see if theres some air in there
Old 11-17-2012, 10:08 PM
jkeaton's Avatar
I'm going to do that, but this is just all the sudden. Have not had it open since last spring when I put the optispark/water pump in.
Old 11-17-2012, 10:40 PM
ok so old cap did not fail. could have a bad cap. not unusual to happen. i tried a aftermarket cap and it lasted 6 months. replaced with oem and has been fine
Old 11-18-2012, 07:05 AM
jkeaton's Avatar
I will do that today. Checked the level this am. Radiator level is fine, expansion tank is about half full. Maybe the expansion tank was too full. But that still does not explain the cap blowing off.
Old 11-18-2012, 12:15 PM
greenmachine96's Avatar
mine did that when my cap went bad. Had people telling me my head gasket was blown lol. I looked at the cap and could see cracks in the rubber so i replaced it and the car never did it again.
Old 11-18-2012, 01:45 PM
BasicConcepts's Avatar
Technical User
isn't the LT1 cooling system 16#?
Old 11-18-2012, 01:49 PM
jkeaton's Avatar
Everything I see says 18#. Just got a new one today. We'll see.
Old 11-18-2012, 02:01 PM
Technical User
i might be wrong its been a while since i have my Z28 and i didnt have it that long.
Old 11-18-2012, 02:17 PM
better bleed her to make sure theres no air in it
Quick Reply: Radiator Cap
