LT1/LT4 Tech 1993-1997
Opinions on Panhard Bar/LCAs
Old 07-20-2012, 12:04 PM
gagger84's Avatar
Default Opinions on Panhard Bar/LCAs
Hey guys, I am looking to start doing some work on my '95 Z28's suspension and I could use some advice and clarification.
I am leaning towards going with Founders Performance parts, but I am not sure if I should get adjustable LCAs and/or panhard bar. I don't plan on lowering my car from its factory height and am looking for about 450hp when I'm said and done, but my aged suspension is definitely in need of some stiffening. Do you guys recommend that I go with non-adjustables, single, or double? Also, what are some of the pros and cons?
Moreover, while I was looking at Spohn Performance, I noticed they offered different kinds of end joints on their LCAs and Panhard Bars. What is the differences from a standard joint to a spherical/poly combo to a Del-Sphere pivot joint?
Any advice would be very much appreciated, thanks in advanced.
Old 07-20-2012, 01:39 PM
i have the spoons lca's, subframe connectors and panhard on the rear of mine and am happy with the results. used the poly ends on both ends of the lca's. the solid ends transfer vibration and such so are not recommended in a dd. i used a combo on the panhard bar ends so the poly would absorb vibrations, used an adjustable panhard bar. if you wish to improve handing i would recommend quality shocks and sway bars, i used strano for both and am glad i did.
Old 07-22-2012, 03:43 PM
gagger84's Avatar
Hey Craby, what are you thoughts on LCAs with a Poly/Swivel Joint Combo? These are the LCAs that I am currently looking at...
1982-2002 F-Body Lower Control Arms- Poly/Swivel-Joint Combination
Thanks again
Old 07-22-2012, 09:51 PM
might be the way to go, i didnt see these with the poly bushing around the steel one. if you get em give us a report. k
Old 07-23-2012, 06:13 AM
gagger84's Avatar
Will do! Thanks again for the help!
libertyforall1776
08-12-2010 09:37 PM
DarkKnight
04-24-2010 12:56 PM
SHOoffSS
LS Series Tech
10-06-2009 03:39 AM
CRanMaro99
09-20-2007 02:26 PM
Quick Reply: Opinions on Panhard Bar/LCAs
