lt1 swap into an ls1 based car
i recently picked up a 99 camaro, it doesnt have an engine or trans, and half an engine harness for 1000 bucks, the car is black with ttops and very straight body, i have an engine and trans out of a 96 camaro, can i use that engine in the car, i have the complete wire harness from cpu to fuse box ect,,i guess my real question is can i use any of the stock ls1 harness
thanks
thanks
RE: lt1 swap into an ls1 based car
Isn't this a little different? Don't most people put the LS1 in the LT1 based cars? Oh well. I get why you're doing it though. I have also been "notified" that the harness has to be swapped.
I belive all the lights and blinkers and horn and such are just in the fuse block so I don't think any of that needs to be changed. I belive it's just the main harness and ECU that has to be changed.
