LT1/LT4 Tech 1993-1997
LT1 rough idle, ticking, poping in exhaust
Old 09-27-2008, 09:28 PM
Default RE: LT1 rough idle, ticking, poping in exhaust
ORIGINAL: green goblin
I have a similar problem on a 96 z28.I had some headers installed and a few days later I noticed the rpm idle dropped from normal 900 rpm to about 500. Every time I step on the accelerator it bogs, feels like its missing all the way to 2000 rpm, after that the car runs fine. Both cats are off but the o2 censors are still on. Can anyone help with this issue? Thanx
You could do as evilbeef54 did, and make sure the plug wires are not touching the hot headers and getting roasted.
Old 09-28-2008, 09:18 PM
stonecoldtrk's Avatar
i accually didnt lose any ground clearance on my headers and they are full length. however the y pipe that comes with hange close to 2 inches lower but it still has some flex so nothing should bust lose or crack.
Old 06-09-2010, 12:23 PM
MikeyB95z28's Avatar
im having the same problem...i did end up having a toasted wire from my headers..after replacing it, nothing changed..tried pulling the plug and changing that,nothing changed....ne ideas?
Old 06-09-2010, 04:03 PM
black95z28's Avatar
everyone on here having similar problems... check your plug wires. all 6 or 8 of them. inch by inch. mostly by headers. if one is damaged, most likely a plug wire fault causing rough running.
Old 06-09-2010, 04:16 PM
if you have a rich condition you can end up with some odd backfiring.
csmiddy
67-69 V8 Tech
12-09-2012 10:12 PM
Chrisd0729
12-29-2011 09:44 AM
CJ51974
06-01-2009 08:59 PM
camarottop95
LS Series Tech
04-04-2009 11:47 PM
BOSS ROC
03-09-2006 01:17 AM
Quick Reply: LT1 rough idle, ticking, poping in exhaust
