LT1/LT4 Tech 1993-1997
Low coolant/water light still comes on!!!
Old 07-12-2010, 05:19 PM
shortterm's Avatar
Default Low coolant/water light still comes on!!!
I'm in the process of resurrecting a '95Z from the dead and just had the whole cooling system worked over. New, hoses, radiator, heater hose, low coolant sensor, master cylinder the whole works. After about a week or two now the low coolant light still comes on and stays on after firing it up and running her after the first 5-10 mins. Guages are fine. She maintains 185-190 all the time. And yes I check the coolant regularly like a mother checks on her newborn. So what's up? Is there another sensor I'm missing? A short in a wire? Thanks for the help comrades!
Old 07-12-2010, 05:26 PM
Stix80's Avatar
you may have an air bubble did you open the bleeder valves
Old 07-12-2010, 05:33 PM
shortterm's Avatar
Well I thought that too(bubble) but where are they? I'm no mechanic and never claimed to be. Just learn as i go. Also, is there a possibility that sensor gets "flipped on" so to speak when filling it up with coolant?
Old 07-12-2010, 05:44 PM
Stix80's Avatar
here you are
Attached Thumbnails Low coolant/water light still comes on!!!-bleeder-001.jpg
Old 07-12-2010, 08:20 PM
Grandpaswagon's Avatar
Check out this link. Lots of great info on 4th Gen cars and common problems / solutions.
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
Also, when bleeding air out of the cooling system, it helps to have the front of the car raised up. I have a steep driveway to use, but car ramps/jack stands will work just as well.
Old 07-13-2010, 08:41 AM
shortterm's Avatar
Default Thanx guys
Stix80 and Gpa'swgn....I appreciate the help
Old 07-13-2010, 12:01 PM
shortterm's Avatar
Default possible cracked heads
well i think i might know the prob. took it back to the mech today and he said the heads may be cracked. Low coolant and no signs of leaks. we'll see!
Old 07-13-2010, 03:07 PM
are you seeing coolant in the oil? pull the plugs and see what they look like.
Old 07-13-2010, 03:08 PM
torque_is_good's Avatar
what in the blue moon are you talking about?
when you perform a visual check is the coolant low?
If not, then unplug that confounded sensor like a gazillion others of us have done because it doesn't work. It only lights on your dash and has no effect at all with the computer
Old 07-13-2010, 03:36 PM
shortterm's Avatar
yeah I've checked the coolant and it's low. But...even after having the cooling system worked over 2 weeks ago it's STILL leaking coolant somewhere! I don't know where. I'm not a mech. That's what my research has been telling me and the mech's opinion as well. I won't know anything til tomorrow though. This is purely speculation at this point. I don't think it's the water pump because there is no visible fluid on the ground. So tell me what you think.
Quick Reply: Low coolant/water light still comes on!!!
