LT1/LT4 Tech 1993-1997
how much coolant and how much water.
Old 03-21-2007, 06:56 PM
camarorz28's Avatar
Default how much coolant and how much water.
ok so i have a question that i've havent been answer just yet, i dont remember what was the capacity of the radiator so if someone can tell me that would be good. now another thing when putting new coolant in your system the coolant goes in the reservoir not in the radiator otherwise bleeding is needed, how much coolant do i put on the reservoir?? i know is 50/50 coolant and water, but how much out of a bottle of coolant?? and how much water do i pore on my radiator to make it 50/50?
Old 03-21-2007, 08:37 PM
Saint_Ali's Avatar
Default RE: how much coolant and how much water.
did you drain the coolant from the whole system, or are you just adding coolant ? just make your own 50/50 mixture or buy the 50/50 mixture
Old 03-21-2007, 09:44 PM
camarorz28's Avatar
mm i'm thinking on draining the coolant from the entire system, what do you mean my own 50/50? if i buy the 50/50 mixture all i need to do is what?? and how many gallons??
Old 03-22-2007, 12:01 AM
Ratman's Avatar
Try measuring the amount of freeze protection you have. After trial and error you will be able to tell whick reading will give you a 50/50 reading.
Old 03-22-2007, 06:53 PM
z28ster's Avatar
also i know they make an anti-freeze specifically designed for GM high performence cars, its like orange looks like Hi-C lol. But its great stuff, and u will need to mix it with water, i forgot who makes it, and too bad i gave the bottle away to a friend, but it is a popular brand and they sell it at any local auto parts store. It keeps the car like almost 20-30 degrees cooler than regular coolant.
Old 03-22-2007, 09:45 PM
Saint_Ali's Avatar
i think it might be the texaco havoline dex-cool, thats the only one i have seen thats orange
Old 03-22-2007, 11:05 PM
camarorz28's Avatar
i'm still confuse on how much to put on it??? what do u mean trial and error??
Old 03-30-2007, 08:26 PM
camarorz28's Avatar
Ok i have another question, when changing the coolant you dont pore the coolant into the radiator but into the reservoir right? do i put the water in the radiator since its a 50/50 mixture?? I know that when coolant heats up it expands, so if it heats up it should flow from the reservoir to the radiator and mix with the water right??
AnalyzeFaith
12-05-2010 05:54 PM
Srane
LS Series Tech
11-25-2010 09:29 AM
shortterm
07-19-2010 07:27 PM
CamaroTeen
06-11-2009 10:28 AM
95camaroaz
01-05-2009 07:28 PM
Quick Reply: how much coolant and how much water.
