LT1/LT4 Tech 1993-1997
Properly measuring crank bobweight?
Old 02-10-2010, 08:04 PM
CraZ28's Avatar
Banned
Default Properly measuring crank bobweight?
After looking at stroker cranks I finally found out about "Crank Bobweight". To correctly balance a rotaiting assembly. The Bobweight of a crank is determined by 50% Reciprocating Mass and 100% Rotaiting weight. Which is determined by the weight of the pistons, rings, and rods. Then the machinest will drill out the holes in the crank determined by the balancing machine.
Old 02-11-2010, 07:53 AM
whammer3024's Avatar
ROTM Winner
cool story bro
Old 02-11-2010, 11:10 AM
murderd96z28's Avatar
Isn't this a place to ask questions and not state facts? Jw
Old 02-11-2010, 11:41 AM
It was a trick, he used a ? in the title. That doesn't count.
Old 02-11-2010, 12:26 PM
CraZ28's Avatar
Banned
Size:  182.0 KBAnd then the rotaiting assembly gets balanced together with the hub, front balancer, and flywheel. Which in my case is an Aluminum Mcleod with removable weight. I would have used my original steel flywheel and had it resurfaced but I was told switching to aluminum is like putting a seventy-five shot of nitrous on it. It does have a steel clutch surface which looks well made reinforced with rivots and such. I think with the added rotaiting mass of a forged 3.75 crank, six hundred gram forged 5.7 I beam rods, and Wiseco forged -5cc Flat Top pistons I will have enough to make up for the flywheel weight loss.
Yooper Z28
01-01-2012 02:00 AM
craby
07-22-2010 12:51 PM
MarkyMark
04-02-2007 03:35 PM
92camaroRS
01-18-2007 04:17 PM
FallenAngel192
10-31-2006 11:38 PM
Quick Reply: Properly measuring crank bobweight?
