LT1/LT4 Tech 1993-1997
Head gasket questions
Old 11-12-2012, 06:27 PM
Mikey.'s Avatar
Default Head gasket questions
Pretty sure the car just blew one or both head gaskets. Noticed the last time I was driving that there was some smoke or steam coming out of the exhaust. Didn't pay it any mind because of the temp changes here. Just drove it to the gas station and its blowing smoke everywhere. Got it home and checked the oil cap and it's this nasty milky color.
Which brings me to my questions.. What do you guys think my best bet is here? I have no idea how many miles are on the motor, all I know is it's not original, but it's no where near new. Do the heads have to be checked? Can I just slap new gaskets on it? Sort of lost here.
It's a 97 Lt1 Trans Am 6 speed.
Old 11-12-2012, 06:48 PM
Randy Bilyea's Avatar
If it didn't overheat, you should be fine with new gaskets. Change/flush the oil/coolant too of course.
You probably have "some" bearing wear from the coolant in the oil, but if you didn't drive it too far or too hard, it might be OK.
Good luck and let us know how you make out.
Old 11-12-2012, 08:14 PM
Mikey.'s Avatar
It didn't overheat. Was hard to start right before I drove it.
Old 11-12-2012, 09:06 PM
BasicConcepts's Avatar
Technical User
first thing is drain that oil out RIGHT NOW... like stop reading this and go drain your oil.
ok now that thats done you can start tearing down the engine, make sure you send the heads to a machine shop to be cleaned and checked for warp/cracks. also might be a good idea to have the valves done since there off the car, or upgrade to some LE heads.
Old 11-12-2012, 09:37 PM
Any time you take the heads off because of a gasket issue, you should take them to a machine shop to get checked out.
Sometimes heads can warp (especially aluminum ones) and cause the gasket leak, not necessarily the other way around.
Old 11-12-2012, 09:57 PM
Mikey.'s Avatar
Any idea how much it is to have a shop check them out? Never gotten into this before.
I'll drain the oil asap.
Old 11-13-2012, 07:00 AM
so the oil looks ok? antifreeze in the oil will ruin the bearings in short order. depending on the shop and what is being done i would say 100 to 1300 bucks. p&p by elliottsportworks being the 1300
Old 11-13-2012, 07:37 AM
Mikey.'s Avatar
The oil looks like a nasty milkshake.
Old 11-13-2012, 08:25 AM
Technical User
If it was driven that way I would start looking for a motor. You can try the headgaskets but there is a good chance you will have a bearing knock within the week after you spent all the work/money on the gasket repairs. In fact I have refused to do headgaskets on motors like this. No matter how much you explain to a customer about the risks 2 weeks after spend $800, when you tell them they need a new engine they are really pissed at you.
Been there, the best is when they say "I don't care I just need it fixed fast"
Old 11-13-2012, 08:39 AM
Oops, looks like Gorn did an Edit instead of a Quote. Welcome to the club!
Quick Reply: Head gasket questions
