LT1/LT4 Tech 1993-1997
fuel pressure and injectors
Old 02-13-2017, 08:51 AM
have you tried a shot of starting fluid in the tb
Old 02-13-2017, 12:10 PM
MKCoconuts's Avatar
If they are spraying in the run position, then that is where you're dropping pressure. They shouldn't spray if the key is just turned to "run" and not started. Once it's started, they will spray in the run position. I could be wrong on this, but I've never see a EFI engine that sprayed fuel until the command to "start" was given.
A simple check to see if it's the check valve is do key on, key off (no start) three or four times. If it fires right up on the third or fourth time, it's most likely the check valve. If it doesn't, I'd look somewhere else for the issue.
Kendagenius
02-05-2017 12:23 PM
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
6v49der
11-17-2007 01:26 AM
Quick Reply: fuel pressure and injectors
