fuel pressure and injectors
If they are spraying in the run position, then that is where you're dropping pressure. They shouldn't spray if the key is just turned to "run" and not started. Once it's started, they will spray in the run position. I could be wrong on this, but I've never see a EFI engine that sprayed fuel until the command to "start" was given.
A simple check to see if it's the check valve is do key on, key off (no start) three or four times. If it fires right up on the third or fourth time, it's most likely the check valve. If it doesn't, I'd look somewhere else for the issue.
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
