Fuel injectors
Fuel injectors
I have 36lbs Accel injectors and I was thinking of replacing. I found some but I dont know if they will work, what is a HIGH IMPEDAMCE AND FOUR HOLES injector. Im really thinking i have some bad ones on the driver side since it floods on 1 side only.
and the 4 hole injectors have 4 output holes its supposed to help atomize the fuel better by causing a finer mist
all i know about high impedance injectors is that the resistance of the injector as higher (12ohms) and the low impedance are around 2-3ohms and require a resistor pack to keep from burning out
I wish i knew somewhere to send mine. No place close that i know off.
Im just thinking, I have a friend with a set of 24lbs injectors, what if I put those in....wil have to retune it for those.
man your right, your in a bad place for injector shops. one in georgia About Us - Fuel Injector Connection
