LT1/LT4 Tech 1993-1997
Fuel injection or carb?
Old 01-21-2007, 11:45 PM
96Z28's Avatar
Default Fuel injection or carb?
hey i have a 96 z28 with a lt4 motor in it, i bought the car mostly for drag racing and it is fairly quick but i would like to go faster. I have considered either upgrading the fuel injection andcomputer or either converting it to a carb. I was wondering which way would be the best for drag racing. I also plan on upgrading the fuel pump and ignition if needed. thanks for any replys!
Old 01-22-2007, 12:00 AM
Default RE: Fuel injection or carb?
What you plan to do won't make much of a difference. The fuel injection and computer are fine, and switching to a carb won't add ant power. You may want to get the PCM tuned on a dyno if you are still using the PCM that came with the LT1. You really need to do all the bolt on mods, and then start working on the internal stuff, and finally tune the PCM again.
Old 01-22-2007, 12:04 AM
shnormo's Avatar
Fuel injection is more consistent. NOS!!! best bang for your buck. Beef up the internals and then like Pete said, get it dyno tuned. Go with a wet shot and then get a timing control and if you wanna run more NOS, get a water injection kit too.
Old 01-22-2007, 12:33 AM
96Z28's Avatar
Ithink i stillhave the stock computer but it has most of the bolt ons, like a bbk 58mm throttle body, larger maf sensor, cai, and a few others as well as the lt4 kit(heads, intake, cam).I bough the car with most of themods already done so im trying to finish what the previous owner started. I also have a 100 wet shot of nitrous. I am sortof woried about using the nitrous because it seems to be leaning out above about 4500. the check engine lite is on also but i had it hooked to a computer and it would not connect to the car so i couldnt get any codes. would a dyno tune take care of all that? or is that something i need to fix before trying to get it dynoed?
Old 01-22-2007, 01:11 AM
shnormo's Avatar
The check engine light is independet of tuning. There might be a bad fuse for the OBDII port. Definately should get that checked out.
Old 01-22-2007, 02:51 AM
95slvrZ28's Avatar
As far as the carb vs fuel injection goes, as Pete stated, it really won't help you much...at least not until you get into making some serious power. They both have benefits, fuel injection is very easily tuned and adjusted(especially with the computer controlling it), but you can get much more air/fuel through a carb system, but it is much harder to tune and get running perfectly. If you're good at tuning carbs, and are making some serious power and need rediculous amounts of air, you could switch over to the carb(s), but with the amount of power you have right now, fuel injection should be just fine, maybe some bigger injectors and then get the PCM retuned.
Old 01-22-2007, 10:49 PM
96Z28's Avatar
what size injectors would be the best for this car? and where is the best place to get a lt4 knock sensor and o2 simulators? also if i have the heads ported and intake matched what size injectors would i need?
Old 03-16-2007, 05:03 AM
INTENSE_Z's Avatar
would suggest to staying with fuel injection if carbs were better then they would be on new performance cars 2day
Z28camaro92
82-92 V8 Tech
18
11-18-2011 06:22 AM
94cam
11-25-2009 12:53 PM
1985RS
07-11-2007 09:54 AM
cumings1965
82-92 V8 Tech
06-11-2007 06:13 PM
County00
03-26-2005 03:53 PM
Quick Reply: Fuel injection or carb?
