LT1/LT4 Tech 1993-1997
Removeing cats?
Old 12-26-2006, 02:03 AM
RicoSuave97TA's Avatar
Default Removeing cats?
if u remove ur catalists converters will this cause u to gain or lose power? pros and cons? when i bought my trans am they were removed and 02 sims were installed i was wonder if this was bad for the car if so im going 2 have some high flow cats out back on
Old 12-26-2006, 03:16 AM
shnormo's Avatar
Default RE: Removeing cats?
As long as your o2 sims are working and not triggering the check engine light, it's okay. You do lose some low end torque but gain power at the top of the power band.
Old 12-26-2006, 02:44 PM
yes my service engine light comes on but they hooked it up to the diagnostic and it was reading that the egr valve wasnt working properly the guy said it was bc of the 02 sims that they needed to be remove got any ideas what i should do thanks
Old 12-26-2006, 02:49 PM
shnormo's Avatar
o2 sims are a pain in the ***. If it was the EGR vavle, it wouldn't start or lose tons of power and it won't idle. So I think it's the sensor for the EGR flow. Personally, I go with high flow cats. Just so your computer doesn't go ape ****.
Old 12-26-2006, 02:51 PM
Thanks man appreciate the advice
Old 12-26-2006, 06:59 PM
When downstream O2 sensors first came on line, the computer program just looked to see if the downstream sensors were seeing a clean exhaust. Later programminggot more sophisticated and looks to see that the downstream sensors are reacting to what the upstram sensors are doing. Beacause the sims always put out the same voltages the computer picks that up and sets a code. So like Norman said, put a good set of cats in. The car will be happy and you will also help the environment.
Old 12-27-2006, 03:58 AM
95slvrZ28's Avatar
Hooray for helping the enviornment! On the other hand, you need to find a mechanic...since when do O2 sensors coorespond in any way to the egr?
Old 12-27-2006, 01:08 PM
Nothing much to do with the EGR , just talking about O2 sims, which really do nothing.
Old 12-27-2006, 11:34 PM
95slvrZ28's Avatar
ORIGINAL: RicoSuave97TA
I was just saying, he needs to find a new guy, 'cause O2 sims and EGR shouldn't be conflicting at all...
camaro34
2010+ V8 Tech
10-03-2010 02:07 PM
chevy_man
02-15-2008 09:31 AM
8485Chevycowboy
09-13-2007 06:32 PM
Quick Reply: Removeing cats?
