LT1/LT4 Tech 1993-1997
anyone have a 1996 Z28 A4 - Stock tune file
Old 07-22-2013, 06:12 PM
njmike's Avatar
Default anyone have a 1996 Z28 A4 - Stock tune file
Does anyone have a stock tune file for a 1996 Z28 (LT1) with automatic trans? I am using JET (formally tuner cats) to read/write the PCM. I wanted to compare tables to see if it has been modified.
I am trying to track down some exhaust noise during deceleration and I am thinking the problem is with the spark table because I am getting a lot of knock retards through the rpm range.
As far as I know it the car is mostly stock (intake and exhaust). I am not sure if someone before me modified the tables or if I have other problems.
thanks in advance if anyone has one!
Old 07-22-2013, 08:02 PM
are you saying the exhaust is not stock or is stock? headers will set off knock sensor.
Old 07-22-2013, 08:17 PM
njmike's Avatar
Sorry, I should have been a little more clear with my post.
As far as I know it the car is mostly stock. The car has an after market K&N intake and a Borla cat back system with stock exhaust manifolds.
I understand that headers would throw off the knock sensor. I was thinking about comparing the tables before I start backing out some timing or chasing down the knock sensor/module (the whole 100 octane to see if it is phantom knock or possibly converting over to LT4 KM).
Old 07-22-2013, 08:27 PM
njmike's Avatar
The noise from the exhaust I started chasing is popping during deceleration after a 3/4 or WOT. My guess is she is running rich because she also has black around the tailpipes.
I have not hooked up my wide-band yet to look at the A/F (I will hopefully get to it tomorrow since I didn't have a chance to do it today).
Old 07-22-2013, 08:52 PM
yep it sounds like its rich, you will get a certain amout of popping no matter what. it takes the computer a small amount of time to shut the injectors down which leaves some extra fuel right after heavy throttle to no thottle, popping is the extra fuel burning in your exhaust.
JGuy07
10-11-2011 09:17 PM
KING_RU
07-22-2008 11:10 PM
Quick Reply: anyone have a 1996 Z28 A4 - Stock tune file
