95 Z28 passenger side Oxygen sensor - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
LinkBack Thread Tools Search this Thread
Old 11-17-2011, 01:51 PM
mloaks's Avatar
Default 95 Z28 passenger side Oxygen sensor
Are y'all removing your O2 sensors repeatedly to troubleshoot doing so on cars with headers?
I have the OEM manifolds and my passenger side defies removal, after removing the starter, heating it up, soaking in PBblaster and using O2 sockets. Didnt pull the Y-pipe because with the starter out, I got some leverage; the sensor sits deep and it is hard to get the socket on fully...
Now it is halfway rounded-off. Any tips? Thankfully the car runs good, and I got the driverside in easily, but want to put the other new Denso in...
At least I got new plugs in while down there!
Old 11-17-2011, 01:56 PM
greenmachine96's Avatar
you could try putting some wax on the base of it where it starts to thread into the exhaust when you heat it up. It stripped with the socket huh? Dang it must be stuck haha. Thats why the only time I replace 02's is if they go bad.
Old 11-17-2011, 03:04 PM
mloaks's Avatar
Quote:
yep, glad it is just of unknown age; seems to work fine...
never thought of wax, tks
Old 11-17-2011, 03:53 PM
Ive never used it but ive been told it helps lubricate the threads to help coax a stuck bolt, or in this case 02, out.
Old 11-17-2011, 03:54 PM
Make sure to use a 6 point socket, the 12 point will round off the soft metal on the sensor.
Old 11-18-2011, 10:30 AM
mloaks's Avatar
Default maybe Tim Tebow can get it out!
Quote:
tks. indeed the rental from auto zone was 6 sided, but the sensors ARE soft... and that location makes getting the socket down fully really tough.
likely havta destroy the old O2 to remove it, but the car is running good and if I pass MD smog, it likely stays. maybe Tim Tebow can get it out!
Old 11-18-2011, 02:28 PM
long tubes make it so easy............
7/8 wrench and as long as the car isn't lowered, you can reach underneath without jack stands or ramps. Seriously, it takes about 3 minutes as long as the headers aren't red hot.
Always use anti-seize when re-installing
Reply
Thread Thread Starter Forum Replies Last Post
Passenger side Knock Sensor REN 93-02 V6 Tech 0 06-18-2011 12:06 PM
Oxygen sensor... 78LT350 70-81 General 9 05-02-2010 10:04 AM
sensor on passenger side mannifold... GSchubes 93-02 V6 Tech 3 03-14-2010 10:09 PM
oxygen sensor 3.4CamaroCDOG 93-02 V6 Tech 2 05-03-2008 01:17 PM
need passenger side side skirt/ground effect tirocz 82-92 V8 Tech 4 03-25-2008 06:38 AM
Tags
02, 95, 96, camaro, censors, chevy, locations, o2, oxygen, passenger, remove, sensor, side, srnsor, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
