LT1/LT4 Tech 1993-1997
1993 Camaro z28 Starter Issues?
Old 11-19-2011, 02:28 PM
chad kennith's Avatar
Default 1993 Camaro z28 Starter Issues?
Okay so about 2 1/2 months ago I got in my car heard a grinding noise, and it would not start. So I went to replace the starter and it was cracked causing it to grind against the flywheel. Anyways I replaced it, everything was fine until last night same thing happened. Why does my starter keep cracking?
Old 11-19-2011, 04:37 PM
usually means its not lined up right or the bolts came lose.
Old 11-19-2011, 04:42 PM
If the engine is misfiring can this cause that? All my bolts were tight. Thanks.
Old 11-19-2011, 05:40 PM
if the missfire happened when the starter is ingaged it could.
Old 11-19-2011, 06:03 PM
Well the car starts hard sometimes.
Old 11-19-2011, 06:07 PM
make sure you have the starter adjusted right when you install. https://camaroforums.com/forum/gener...himming-20175/
Old 11-19-2011, 07:45 PM
When I replaced the part today they gave me a notice that GM put out that said it could be caused by, CP Sensor, Fuel Regulator, Pcm, or timing belt. My car doesn't make any whining noise when I start it up.
miichielx
06-02-2014 03:40 PM
pcarollo
09-13-2012 06:51 PM
Chaotic94
06-02-2012 04:55 PM
uestraven
70-81 V8 Tech
08-11-2011 08:00 PM
DaTruth69
05-28-2009 04:10 AM
Quick Reply: 1993 Camaro z28 Starter Issues?
