LT1/LT4 Tech 1993-1997
93 Z28 starts then stalls
Old 03-29-2010, 08:33 PM
KENCO's Avatar
Default 93 Z28 starts then stalls
93Z, getting intermittent spark at the coil. I think it might be the optispark, but is there a sure way to know? Could it be the module? I am thinking the pickup in the opti is not sending the signal correctly to the computer to fire the coil.
I want to make sure it is the opti before I take it all apart.
Any input?
Old 03-29-2010, 10:35 PM
Size:  52.4 KB[/QUOTE]
Old 03-29-2010, 11:43 PM
dc14u2no's Avatar
throwing any codes?ses light ?could be module but....opti can cause it to throw all kinds of bad codes
Old 03-30-2010, 04:43 AM
KENCO's Avatar
Originally Posted by craby
It's hard to see that print but does it say to hook up a Tech1? I do not have a Tech1.
KENCO's Avatar
I will check for codes today.
Old 03-30-2010, 05:35 AM
KENCO's Avatar
How do I test the coil? Could it be a bad coil?
Old 03-30-2010, 05:38 AM
if u read though it u would notice that its checking for a pulse on the low resolution or test conector a. u can do this and most all the tests with a ohm/volt meter. a bad opti does not always throw a code.
Old 03-30-2010, 02:23 PM
found this lookin for other 4th gen sites.
http://www.camaroz28.com/forums/showthread.php?t=601565
Old 03-30-2010, 03:07 PM
KENCO's Avatar
Good stuff, thanks!
I just got a hold of a determinator scanner from my buddy, I am going to hook that in to see, what if any codes have come up and also to see if the pickup is showing rpm.
Boy do I really want to make sure it is the opti before I do it........
Old 03-30-2010, 08:07 PM
KENCO's Avatar
Ok, I scanned everything, NO codes. And I am get rpm signals when cranking the engine, that means the opti pickup sensor is working. So I will test the ignition coil or get a temp to see if that is the problem.
Quick Reply: 93 Z28 starts then stalls
