LT1/LT4 Tech 1993-1997
93 Z Won't start
Old 11-09-2014, 08:48 PM
diddyrox68's Avatar
Default 93 Z Won't start
93 Z28, turn ignition and dash wakes up, turn to start and nothing. Starter is fine, changed neutral safety switch and ignition switch. Cleaned all wire ends and nothing. I am stumped. Any ideas??
Old 11-09-2014, 08:58 PM
Security lamp lights when you try starting??
Old 11-10-2014, 06:18 AM
Size:  72.4 KB Name:  P1190002.jpg
Old 11-10-2014, 07:59 PM
diddyrox68's Avatar
turn switch to run and security, SES, Check gauges, and ABS INOP lamps are on. Turn to start they stay on and coolant level lamp comes on.
Old 11-10-2014, 08:44 PM
pete hit it. security light most times means vats is acting up. may want to bypass it.
Old 11-10-2014, 08:48 PM
vats bypass and more. click/look at 25 and 25.5 here https://camaroforums.com/forum/93-02...62/#post557634
Old 11-29-2014, 01:42 PM
diddyrox68's Avatar
Still workin on starting issue. Trying to avoid vats bypass. Thanks for the input.
Lakatrae
03-29-2014 10:59 AM
rdb357
03-30-2008 08:25 AM
JTyler
08-31-2007 10:21 PM
coco
08-13-2007 10:33 AM
Quick Reply: 93 Z Won't start
