LT1/LT4 Tech 1993-1997
short throw shifter....
Old 09-27-2008, 07:38 AM
stealthy95z's Avatar
Default short throw shifter....
bought the car with a short throw shifter already installed. it seems like whoever did this may have ripped out whatever sound/heat insulation that is supposed to be there. its throwing a ton of wind/heat up from the shifter area through any cracks in the center council (ash tray and all other areas)
so anyway does that sound right or might he have really been a retard and cut away something he shouldn't have?
and where can I get the insulation barrier to take care of the issue? I assume like the stuff they use to soundproof a trunk with a subwoofer will work?
Old 10-12-2008, 03:42 PM
luvmysccamaro's Avatar
Default RE: short throw shifter....
When I installed my Short shifter, I need to trim the rubber thing that goes around the shifter. The previous owner was probably lazy and didn't want to trim it so that is probably why there is hot air coming out. I'm not sure were you could get one. Do some research and try Ebay or your local Chevy dealer.
Xios
10-04-2014 12:16 PM
jasonh3609
09-16-2011 09:02 AM
camarokid1
05-01-2007 11:52 AM
jays94camaro
04-24-2007 04:08 AM
Deezil13
08-07-2006 04:05 AM
Quick Reply: short throw shifter....
