LT1/LT4 Tech 1993-1997
1994 Z28 Over Heating
Old 04-20-2013, 11:04 PM
rockinjohnny's Avatar
Default 1994 Z28 Over Heating
Hey Folks,
Looking for some advice, my 1994 Z28 is over heating. I have now replaced the water pump and radiator. Water pump was bad and the radiator was clogged but it still over heats and blows the coolant out of the radiator with the cap off or the resevoir if the radiator cap is on. There is no steam coming from the tail pipe and the oil is crystal clear. Any advice would be greatly apreciated.
Old 04-22-2013, 03:13 PM
have you been bleeding the air out good. https://camaroforums.com/forum/lt1-l...-system-66742/
Old 04-22-2013, 03:45 PM
If that happens right away, then that's a bad sign of a blown head gasket. But if that happens after the engine heats up, that's "normal" as far as bubbling over with the open radiator is concerned, but not normal for it to do that at the reservoir.
Old 04-22-2013, 04:22 PM
Make sure your fans are running properly
Old 04-23-2013, 08:38 AM
Does anyone have a picture or description of the third bleeder assembly that is supposed to be under the throttle body?
Old 04-23-2013, 08:59 AM
I have been bleeding the air from the 2 screws located on the hose and the thermostat cap but have not been able to locate this third bleeder assembly.
Is there a step by step diagnostic/test procedure for the cooling fan system?
Old 04-23-2013, 09:03 AM
when the car heats up look under the hood to see if the fans are going
Old 04-23-2013, 09:22 AM
The fans are not spinning once the thermostat opens or even when the coolant begins to boil over.
Old 04-23-2013, 10:40 AM
then that's the problem. check the wiring and the fuses.
Old 04-23-2013, 11:07 AM
Will do. Is there a point to point wiring/component troubleshooting procedure for the fan system because thed fuses are good?
Quick Reply: 1994 Z28 Over Heating
