LS Series Tech 1998-2002
Plugs for my 01 SS
Old 06-19-2010, 08:48 PM
distefanos's Avatar
Default Plugs for my 01 SS
My 01 SS just crossed 100K and needs Plugs Changed, Stories vary on what i should replaced them with, Can anyone Help Please?
Old 06-19-2010, 08:56 PM
Massey's Avatar
Stay away from the E3 and Plat +4 from bosch. GM recommends using iridium plugs that run about $6.99 each. OEM was NGK/AC Delco Iridium. I would put either Autolite Iridium or NGK iridium in the engine. If you cant afford that then go with Autolite Double Platinum.
Massey
Old 06-20-2010, 07:48 AM
maudyZ28's Avatar
I just run coppers, no difference really. At moment got champions gapped at like 0.38" I think, you can run anywhere between 0.3 to 0.6" im not an expert but some run hotter or colder, ie like N2O or not. For a better idle, go with the smaller gap. Previously had NGK TR5s too or TR55 are good
Old 06-20-2010, 12:53 PM
ive used the tr55 and bosch +4 and both have worked fine. i am using a msd coil so i figured the +4 would do fine and did. only thing that would work when i was running ridiculously rich.
Old 06-20-2010, 06:40 PM
usnfenix's Avatar
i use NGK V power and for ls1's heard alot of people recommend these plugs. in the end everyones gonna tell u different stuff and honestly they all are good and as long as your not running nitrious it dosent matter to an extreme degree at all
Old 06-21-2010, 11:58 AM
blue_thunder01's Avatar
I use the NGK stock# 3346s..
hoursetraitor
04-25-2011 10:14 PM
CraZ28
02-14-2010 10:15 PM
purpl96
11-26-2007 05:52 PM
84 z .....
09-25-2007 11:25 PM
deang423
08-13-2005 09:11 PM
Quick Reply: Plugs for my 01 SS
