Short tube vs. long tube headers
Old 01-31-2009, 07:24 AM
rsh3429's Avatar
Default Short tube vs. long tube headers
I want to replace my stock headers with aftermarket. I have an 02 Z28. I like the shorts because they would be easier to install and would bolt up to stock cats. I want to build the exhaust a piece at a time and do it right. I guess my question is, would shorts be worth the time and money to mess with. I know that long tube headers offer better performance but are more difficult to install and would require an extensive exhaust rework. I am not looking to ever build the engine. I am more interested in it running the best it can with bolt ons. I have already swapped out the stock air box lid with an SLP lid and smooth bellows, thanks...Russ
Old 01-31-2009, 10:54 AM
robmnrd's Avatar
Shorties will get you 5 horses, and a little bit louder exhaust note. IMO, not worth the money even if they are cheaper than LTs. They will definitely be easier to install though.
Old 01-31-2009, 12:04 PM
Saint_Ali's Avatar
they are called exhaust manifolds not stock headers.In theory, the tube length affects the RPM at which you see your largest gains. Longer tubes produce torque at lower RPM. Shorter tubes move the peak gains upward in the RPM range. Longer tubes may limit peak HP, because of the increased pressure loss. Shorter tubes may make more peak HP. Traditionally, long-tube headers are the best for street cars, mid- and shorter lengths for track cars, that never operate below 4,000 or 5,000RPM.
Long tubes may also create ground clearance problems, particularly with lowered cars. There just isn't much room on the drivers side for the collector to come straight back, and include a cat (if you plan on using a cat).If you plan on staying emmissions legal you will need to get a catted y-pipe and the headers you get will need o2 sensor,A.I.R. and EGR hook ups.
Old 02-01-2009, 06:45 PM
rsh3429's Avatar
thanks for the responces, think I'll keep it stock.
Old 02-01-2009, 07:42 PM
SpecterGT260's Avatar
Ninja Administrator
I dont agree. you never want pressure in your exhaust system. all you want is a continuous flow of gasses. shorties cannot make low end torque as well as LTs because they do not dissipate heat as well thus do not scavenge as well. in higher rpm ranges the gasses are moving so fast that the scavenging effect lessens. so LTs will still tend to make higher peak hp, but the differences will be slight.
Old 02-10-2009, 04:12 PM
RubberDucky's Avatar
What would be a good set of headers to put on a 89 2.8 V6? Or am i at a loss because its a V6?
Old 04-04-2009, 02:21 PM
91rsfoo!'s Avatar
i got the same question i also have a v6?
Old 04-04-2009, 11:12 PM
carguylt1's Avatar
The "other" car comes with headers factory. you don't have to run a duel act a single after the y should work. but LTS still drag even with a drag launch kit my buddies z with mids scrubed some times. If you want the most out of your car with bolt ons you have to upgarde the exhaust from the "header" back.
SS_2000
LS Series Tech
13
04-24-2010 11:25 AM
jbe123
09-07-2007 12:40 AM
8485Chevycowboy
08-01-2007 06:25 AM
RicoSuave97TA
01-01-2007 05:39 AM
Saint_Ali
08-16-2006 05:00 PM
Quick Reply: Short tube vs. long tube headers
