Carb Trouble! Need help!
Ok So I have Holley 1850s on top of a preformer rpm intake manifold. I can bring my car down to proper idle rpm with out it dying. The vacuum is fluctuating from 17-10. I can tell there is a leak around the intake, the vacuum advance works, the brake booster is holding vacuum as well. Idk what to do?? Need help!
No adapter plate, it didnt have one on it before I pulled the carb off.
And I'm sorry I ment to put I think there is a leak around the intake. It's my last guest on what's going on. And I think the carb was sealed fine. Has a brand new gasket on it.
