Buying A '68 Camaro
Old 02-09-2010, 05:47 PM
acjwberger's Avatar
Default Buying A '68 Camaro
Looking at a 1968 Camaro. It has a 396 cubic in. and only a 10 bolt rear. Is this correct. I know some came with 12 bolt rears. Shouldn't a big block have a 12 bolt rear? Also how do you take care of the solid vinyl top, does it need any special care? Thanks
Old 02-09-2010, 11:10 PM
camaroboy68ss's Avatar
June 2010 ROTM
Ride of the Year 2010
you might want to check the vin # of both the motor and car. if it is the original motor the last 5-7 digits will match. with the 10 bolt though makes me think that it was a small block car originally becaue im pretty sure all big blocks had 12 bolts. srry i dont know on how to take care of the vinyl top my 68 had one originaly but it was off when i bought the car and i dont want on it because they rust to easy i had to patch part of my roof.
Old 02-12-2010, 03:44 PM
Y2K's Avatar
Y2K
Y2K is offline
A factory big block car would have a 12 bolt rear and multi-leaf springs.
If it's an automatic it should also have the turbo 400 trans.
shaun91
09-09-2010 08:33 PM
Wilsonation
04-06-2010 07:57 AM
redngold88
11-17-2009 07:12 PM
ajonesz28
06-28-2008 05:50 PM
Zanetar
08-11-2006 01:52 PM
Quick Reply: Buying A '68 Camaro
