Headlight Sensor (Photocell) location
Hi there!
Anybody can tell me where the automatic headlight sensor on 2001 Camaro SS is located? Anyone has a circuit diagram? Lately my headlights stay on all the time - I would assume the photocell is shot or dirty? or a "blocking diode" is fried somewhere in the circuit..Any suggestions?
Thanks
Thanks
RE: Headlight Sensor (Photocell) location
No, there is no little bump on the dash. And the headlight switch only overrrides the system when headlights are off (I.e. turns them on) but does not switch ligths off once they come on.
Any other suggestions, anyone?
The sensor is in the dash. If you look in the vent on the top of the dash well enough you should be able to see it. I guess an easy test would be to make sure its clean and shine a bright flashlight on it and see if your lights go off.
bill bill bill , the flashlight wont work. if the lights stay on in the day light the sensors bad. HEY you could always pull the e-brakeone notch and kill all the daytime running lights!!!!!!!!!!!!!![:@]
ORIGINAL: bluovlh8er
