exhaust popping and cutting out
I am having issues with popping noises in my exhaust and cutting out/surging. Having had this problem before, I first checked the plug wires and found number 5 burned through on the header. I replaced the wire and installed a heat shield boot and the problem seemed to be solved, until the engine warmed up and then the popping, cutting out resumed. I checked the temps of each pipe on that side and got about 450 on 1, 3, and 7 but #5 was only 210. Everything seems to start after 15 minutes or so of driving when the engine warms up. Any ideas?
RE: exhaust popping and cutting out
gw your symptoms can come from a variety of problems and i would suggest you start with some basics to avoid chasing your tail on this one. not knowing the age and or condition of the engine id do a compression test first to be sure we have viable mechanicals on this one. if this proves good then we can look at possible ignition and fuel causes kurt
