engine swap 80-81 camaro - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 06-30-2008, 01:24 PM
Default engine swap 80-81 camaro
can the stock v6 engine in an 1980 or 1981 be replaced with a small block. i'm looking at a possible project car and need some help. thank you
Old 06-30-2008, 10:45 PM
Saint_Ali's Avatar
Default RE: engine swap 80-81 camaro
yes, this is the most common thing done now days.you most likely will have to upgrade the car to accompany the new v8, suspension,fuel system,rear end and the trans that will match up with the small block. what kind of small block were you looking into ?
Old 07-01-2008, 01:15 AM
I once saw a porche with a diesel locomotive turbo on it. This proves you can do anything your little heart desires......Well just about anything. As the car was doing 200mph it got air underneath it and sent it sailing. [&o]
Old 07-01-2008, 10:44 AM
i have a 355 small block with aluminum heads and a th350.
Old 07-01-2008, 11:03 AM
As far as conversions go, that will be an easy slip-in job since the car also came with a small block. And you don't have to worry about any computer controlled crap to have to make work either. New engine, trans, and motor mounts frame brackets (I believe) and you're most of the way there.
Reply
Thread Thread Starter Forum Replies Last Post
L98 to 67 Camaro engine swap help JustinA 67-69 General 0 07-14-2014 10:10 PM
74 Camaro Engine Swap Lee74 70-81 General 2 04-20-2013 08:50 PM
'75 camaro engine swap Tomg303 70-81 Projects 1 09-03-2012 11:46 AM
84 camaro engine swap v6-305 or 350 ?? youngbuck84 82-92 General 9 10-20-2009 05:22 AM
'88 Camaro Engine Swap 88Camaro 82-92 General 0 04-21-2006 01:30 PM
Tags
350, 454, 81, block, camaro, camero, chevy, engine, locomotive, moter, motor, small, swap, swapped, swaps, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
