BURN OUTS?(HELP)
Old 06-29-2008, 02:16 AM
2002SLP's Avatar
Default BURN OUTS?(HELP)
can any 1 tell me how to do a burn out?i have a 2002 m6 ss n last night i was trying to do a burn out by letting go the clutch , n with my right foot pressing the brake n gas pedal.my problem is it just burn out a lil n then the car just turn off on me...does any1 know y it turned off an what i did wrong?
Old 06-29-2008, 04:03 AM
MadMikeZ28's Avatar
Default RE: BURN OUTS?(HELP)
You keep doing burn outs you are just going to end up asking how to fix the stuff you screwed up.
Old 06-29-2008, 05:49 AM
blackz87's Avatar
Hold the clutch down and rev it up to 6000 RPMs and pop the clutch and you will have the burnout of your young life.
Old 06-29-2008, 06:47 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
X2 with mike. If you go to the track and ask them you will get better results. Although, I would LOVE to see a 6k drop in an 02.
Old 06-29-2008, 07:15 AM
blackz87's Avatar
ORIGINAL: cplthomas
That would be the last burnout by that owners car. Lets see if he gets the hint.
Old 06-29-2008, 10:48 AM
frostlime69's Avatar
ORIGINAL: 2002SLP
If you keep tring, you will break something. M6 was not meant to do burnouts. Heres a tip though to help break the tire's loose and save your clutch. Spray a little bit of bleach on your rear tires then give it a try. Do so at your local race track!
Old 06-29-2008, 01:10 PM
z28rob18's Avatar
just rev it up and dump the clutch 6k rpm is a little much
Old 06-29-2008, 01:18 PM
ORIGINAL: blackz87
And make sure you keep a bushel basket in your car so you can gather up all the parts of the rearend that blow out the back.
Old 06-29-2008, 01:22 PM
BeraniHull's Avatar
Oh dear you guys are gonna have him kill his car :'( He's a fellow camaro owner guis!
Your car seems to be stalling out...that's why it's turning off...(I'd assume).
Listen to cplthomas and ask some guys at the track or a friend that knows how to do one or something.
Old 06-29-2008, 01:26 PM
z28rob18's Avatar
ive never had any problems wit drivetrain and the only way i no how to do a burnout in a manual is to dump the clutch
Quick Reply: BURN OUTS?(HELP)
