Humming noise in car wile driving
Old 09-12-2009, 10:50 AM
Chevykicksbut's Avatar
Default Humming noise in car wile driving
Hello all, I have a 2002 camaro 3.8 5 speed with 56000 miles one it. Wile I am driving down the road, thier is a humming noise in the car. The tone gets "higher" as I increase speed and gets "lower" as I decrease speed. Originaly I thought it might be the tires?? I don't know if it is comming from the front or rear. I have not checked the rear diff fluid. Your help would be aprieciated
Old 09-12-2009, 11:07 AM
Old 09-12-2009, 11:16 AM
Does it sound like this......hmmmmmmmmmmmmm? Is it a "whiney" sort of hum?
Could be your rear gears, either from worn bearings in the differential, or worn outer wheel bearings putting an improper load on the ring & pinion gears. You really need to know for sure what area the hum is coming from.
Old 09-12-2009, 11:54 AM
and if u have a two piece drive line it could be a carrier bearing. is there any vibration?
Old 09-12-2009, 02:30 PM
I guess it sounds like, when I'm decelerating one of those old air raid sirens just not neerly as loud haha, but the noise does not intensify if I give it gas or let off, and the noise is comming from the rear end
Old 09-12-2009, 02:32 PM
And to answer craby, no thier is no vibration
Old 09-12-2009, 03:51 PM
Check the oil level in the rearend. Or better yet, change it if it's never been.
Old 09-12-2009, 04:08 PM
Trollsmeesh's Avatar
Go post the question in another thread like 4th gen, this isn't the place for questions like that.
On another note, welcome to the forum!
Old 09-12-2009, 05:21 PM
[QUOTE=Trollsmeesh;363121]Go post the question in another thread like 4th gen, this isn't the place for questions like that.
so what is general tech for?]
Old 09-12-2009, 05:44 PM
This question, and it's answers, can pertain to any year car. Being in general tech can broaden the reader base. As you were!
Quick Reply: Humming noise in car wile driving
