1996 Camaro starts but stalls immediately - Camaro Forums - Chevy Camaro Enthusiast Forum
Reply
Thread Tools Search this Thread
Old 03-11-2008, 10:46 AM
Default 1996 Camaro starts but stalls immediately
Please Help!!
Over the last month I have been having trouble with my 96 camaro. The car starts up but immediately dies out. I have replaced the wires, spark plugs and had the ignition module tested and it was ok. I also had the crankshaft sensor tested and it was fine. The wiring harness also was checked for loose connections and that was ok. I replaced the ignition sensor and it worked great for about a week and then it started doing the same thing. My fuel pump was also tested and it was working fine so I am confused as to what the problem is. Any advice would be helpful
Old 03-11-2008, 10:53 AM
camaro_burns_all's Avatar
VIP member
Default RE: 1996 Camaro starts but stalls immediately
did you check the distributor and the rotor cap? you might also have a bad starter solenoid
Old 03-11-2008, 11:04 AM
Hi,
My camaro doesn't have a distributor it has ignition coils. I am not sure if my mechanic has checked the starter but I will ask him to do it. Thank you for your reply to my question. Do you think it might be my power controle module.
Old 03-11-2008, 11:22 AM
VIP member
Well I would have to say go ahead and check to see if the PCM is working fine. The PCM is supposed to control the fuel injection and ingition timing. You already said the ignition module is fine and the fuel pump is working fine so im not sure. You use the term PCM which also now reffered as ECU. Your ECU controls IAT, MAP senor, TPS, O2 Sensors. If all those are fine, then I dont think its the ECU thats giving you a problem
Give it a shot and see what happens
Old 03-11-2008, 11:40 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Vacume leak?
Old 03-11-2008, 01:07 PM
Thank You for your suggestions, I will try those out.
Old 03-11-2008, 02:57 PM
its either a vacume leak, or you spider is out (injectors) i had the same thing happen on my 97 silverado
Old 03-11-2008, 05:54 PM
Saint_Ali's Avatar
sounds like it could be a clogged cat also
Old 03-11-2008, 06:18 PM
or an egr perhaps???
Old 03-11-2008, 07:08 PM
Your car uses two crank position sensors. A high res sensor (24x) located behind the front damper. This sensor is used to control spark from idle to about 2000 RPM. The other crank sensor, on the side of the block is the low res sensor, which handles the spark during cranking and when the engine is over 2000 RPM. Being that the car starts, it indicates that the low res sensor is doing its job, so take a look at the high res sensor as it may be defective or have wiring problems.
Reply
Thread Thread Starter Forum Replies Last Post
93 Z28 starts then stalls KENCO LT1/LT4 Tech 13 04-01-2010 05:05 AM
It starts and stalls immediatelly! Help plz! oasr987 82-92 V8 Tech 7 10-04-2009 02:49 AM
1996 Camaro RS stalls when slowing down RFxCamaro 93-02 General 5 07-10-2008 12:48 PM
Starts and stalls. Foskey 93-02 V6 Tech 5 08-18-2007 01:00 PM
same problem starts stalls out mongo 82-92 General 2 11-14-2006 10:38 PM
Tags
1996, 96, camaro, camero, car, cheverolet, chevy, cranks, dies, forums, ignition, module, silverado, stalls, starts, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
