1996 camaro ss power window problem
Old 05-30-2007, 10:06 PM
spittyss05's Avatar
Default 1996 camaro ss power window problem
drivers side window frozen...switch when depressed is making power windowcontrol module make a funny noise tried to change power window module. but it kept making the same noise....passenger window ok i guess not on the same wiring scheme...need help.......
Old 05-30-2007, 10:18 PM
MadMikeZ28's Avatar
Default RE: 1996 camaro ss power window problem
Maybe the motor is froze
Old 05-30-2007, 10:22 PM
t9ojetpilot's Avatar
[X(] without gettin into the wiring schematics id have to guess you have a bad motor causing the module(circuit breaker or relay) to trip and create the noise your hearing. do you have the mad skills to enable you to jumper the motor itself to see if it is even working thus bypassing all the other circuitry to eliminate the motor itself as the problem kurt
Old 05-30-2007, 10:29 PM
spittyss05's Avatar
thanks kurt,
i could, but i didn't want to pull the door panel. i guess i'll have too.
Old 05-31-2007, 07:24 PM
[X(] there may be a connector at the kick panel or at the module which may give access to the motor wires after the other components but i dont know for sure on that model as i have yet to get into it that far(i got manual windows).. if you have a local junkyard maybe go take a peek at a similar year this way you can cause carnage to find your answers before breakin into your own. ill take a look at the schematics i have for my 95 and see if i come up with anything that helps kurt
Old 05-31-2007, 08:02 PM
bluovlh8er's Avatar
just connect the b harness into the tak and run new leads to the speed reducer sensor and in the 09 it would be nice not to have power antena's also with or without the b harness.
p.s. we need to run up to wallie world and buy some eletrickal tape to wire in the *** so everything is a go on the power switch.....
Tar Heel
08-21-2009 03:55 PM
ForgetfulRegrets
01-15-2007 11:30 PM
Rise65
11-06-2006 11:09 PM
Shifty
02-19-2006 04:20 PM
Quick Reply: 1996 camaro ss power window problem
